CAREFUL !! Do not jump to adjusting the bearings to L until you've checked all possibilities. If you must adjust the bearings, you need first to open the crankcase, and for that i recommend you check out the videos at
http://abikesupport.ning.comThis is a great but underused site that has lots of repair videos. In order to access the screws that secure the bearings to the crankcase housing, you need to open up the crankcase and lift out the rear wheel. Then be careful unscrewing the tiny screws, as they can get damaged in the process. Be sure to set both sides the same. However, I would not be confident that bearing tension is the problem.
Did you buy the bike from Mayhem? If so, you should try contacting their support by phone. You can also email at support.a-bike.co.uk, but calling may be quicker.
Look to see if the chain is stuck or gets stuck between the wheel and the housing when you pedal. Is there any damage to the tire from the chain? See other posts about chain problems and rear wheel problems. Look at my other posts, also check this post about recent chain problems:
viewtopic.php?f=2&t=1344
