Gear ratio information about different models of the A-bike
Postby Amuro Lee on Fri Aug 27, 2010 7:09 pm
A-bike / A-bike Plus / 6" wheeled A-bike Smart
Dual Chain ratios: 14:8 and 35:9
Tyre Size: 15cm/6" diameter x 3.2cm/1"
Crank length: 140mm
Gear inches: 6" x 14 ÷ 8 × 35 ÷ 9 = 40.83"
Metres of development: 0.15m x π x 14 ÷ 8 × 35 ÷ 9 = 3.21m
This means that the bike travels about 3.21 metres per crank rotation.
Gain Ratio: 150mm ÷ 2 ÷ 140mm x 14 ÷ 8 × 35 ÷ 9 = 3.65
A-bike City / 8" wheeled A-bike Smart
Dual Chain ratios: 14:8 and 33:11
Tyre Size: 20cm/8" diameter x 3.2cm/1"
Crank length: 140mm
Gear inches: 8" x 14 ÷ 8 × 33 ÷ 11 = 42"
Metres of development: 0.2m x π x 14 ÷ 8 × 33 ÷ 11 = 3.30m
This means that the bike travels about 3.3 metres per crank rotation.
Gain ratio: 200mm ÷ 2 ÷ 140mm x 14 ÷ 8 × 33 ÷ 11 = 3.75
What is "gear inches"?
http://en.wikipedia.org/wiki/Gear_inches
What is "metres of development"?
http://en.wikipedia.org/wiki/Gear_inches#Calculating_metres_of_development
What is "gain ratio"?
http://www.sheldonbrown.com/gain.html
Information about measuring gears:
http://en.wikipedia.org/wiki/Bicycle_gearing#Measuring_gears
Gear ratios comparison among tiny wheeled folding bikes:
http://www.abikecentral.com/forum/viewtopic.php?f=2&t=1369
Re: Gear ratio information about different models of A-bike
Postby Rob Friedman on Sun Aug 29, 2010 12:15 pm
has anyone tried or figured out if a internal gearedhub ie: a 3 speed or 6 speed a:could be used and b: would make a difference?
Rob Friedman
Postby Stevbike on Sun Aug 29, 2010 11:55 pm
Although I ride a copy version of the bike, the gear ratio is just right for the bike. It is not designed for high speed riding, just short trips. The extra gearing would add greatly to the cost of the bike as well. The basic design of the bike really well though out.
Postby Rob Friedman on Mon Aug 30, 2010 1:45 am
I too ride a copy that is very much like yours 8" solid tires.. but while this nis not for a long ride it just came to me that an internal gear hub might make a difference
Rob Friedman
Postby Stevbike on Mon Aug 30, 2010 2:10 am
It would be interesting see how a multi-speed hub could be placed in the tiny rear drive wheel. It would be interesting see it get at least 55 to 60 inches of gearing so the bike could reach at least a 18 to 20 kph average speed.
I get about a 12 to 14 kph average speed with the 42 gear inches. I do not know how you find the bike at speed but on slight down hill sections anything above 25 kph is a bit scary on a A-bike design. The wheel base is on the short side to handle any high speeds that could be asked to do with higher gear ratio's. If greater distances are needed, a bike more suitable these needs should be used, at least in my thinking.
Service Provider
Postby prenadixitt on Fri Nov 28, 2025 8:08 am
If you want real comfort and a friendly connection, Greater Noida Escorts Service is a great choice. The girls are charming, polite and make every moment enjoyable. Their ability to create a relaxing vibe is impressive.
prenadixitt
Delhi Call Girl
Postby kavyaaroradelhi on Tue Dec 23, 2025 11:23 am
Delhi Call Girl provide much more than just a physical experience; many also provide you with emotional support, companionship, and holistic experiences adapted to your individual needs—all at an affordable cost.
kavyaaroradelhi
Postby Call Girl in Gurgaon on Fri Feb 06, 2026 11:43 am
Gurgaon Escorts will help you discover your ideal partner. The process of finding attractive and seductive Escorts in Gurgaon becomes easy to follow. The leading Gurgaon Escorts Service manages all aspects of the operation. The connection with beautiful Call Girls in Gurgaon will bring you both absolute pleasure and total contentment.
Re: Service Provider
Postby ns903816 on Mon Mar 16, 2026 7:32 am
Planning a trip to Larnaca and wondering about the best way to get around? Whether you’re visiting for a summer holiday, business trip, relocation, or long-term stay, choosing the right car rental companies in Larnaca can completely transform your experience in Cyprus.
quicklister
ns903816
Users browsing this forum: Google Adsense [Bot] and 58 guests
