Hi guys.
after I read many topic of this forum which tell that original is better than imitation, at the end, I bought the new original A-bike from one distributor in Germany. yay....
After that, it just like my story below.
The A-bike was bought from one distributor in Germany. Below is the detail of that distributor
Futurumshop GmbH
Gocher Landstraße 2
47551 Bedburg-Hau / Kleve
Telefon: +49 (0)2821-7134118
Telefax: +49 (0)2821-7134117
E-Mail: support@futurumshop.de
12/12/2008 I bought an A-bike from futurumshop
17/12/2008 I got the A-bike.
I found a small assembling problem. The Main Locking Buttons of the rear side was not in the right place. It didn’t lock the upper tube at all.
18/12/2008 I tried the new A-bike.
After the Main Locking buttons has repaired. I was cycling around the city for about 3 hours and the gear started make some noise each time I pedaled the A-bike. At the end, the rear wheel didn’t spin anymore, when I was pedaling the A-bike.
19/12/2008 I went directly to the futurumshop to complain about The A-bike. I got the new one. Before I went home, I checked the new A-bike first. I found that a small plastic part inside Crank Case which is to protect the chain and the Rear Upper Tube when the A-bike is folded was not assembled in a right place. This plastic part was too long and touches the rear wheel. Because there was only one A-bike left in futurumshop I should wait for the next shipment from UK.
5/1/2009 I got the second new A-bike
I found a small assembling problem again. One screw of the front wheel fell when I was unfolding the bike. I repaired it again before I used it. I went around the city for about 3 hours and the gear started make some noise again like the first A-bike.
so my conclusion is, Original is not always better than Imitation.
